ABS Light Functions
jasonvitsi
Motorradtyp: F750 GS
Greece
ABS Light Functions
Ungelesener Beitrag von jasonvitsi »
Hello to everybody, i have a F750gs and i have noticed that on this models when the traction control engages the traction control light flashes on/off. While the ABS light doesn't have this future. Although i have noticed that on other models like r1250gs or s1000xr when the ABS engages the ABS light flashes. So it seems like on my motorbike the ABS light is only used to show if the ABS has been turned on or off from the menu and will not flash while used. Does anybody know if there might be a setting to activate this flashing mode on the ABS light? I have searched a little bit on the BU and couldn't find anything in the X_KOMBI3 , there are some settings that have to do with abs in the X_BCO section but couldn't figure out which one might do the trick..... :traurig: :crazy:
Danksagung erhalten: 24 Mal
Re: ABS Light Functions
Hallo Jason,
ich habe alle Möglichkeiten in X_KOMBI3 und X-BBCO durchgesucht und nur das hier gefunden
X_KOMBI3:
"lin_StatusABS_Enable" (Aktiviert die Übertragung der Status-ABS-Info auf Navi)
ob sich das auf das Dispaly auswirkt müsste man testen.
