63128395631 LED HEADLIGHT FA codes
kuanyi
Motorradtyp: R1250GS
Hat sich bedankt: 1 Mal
Taiwan
Beitrag von kuanyi »
63128395631 LED HEADLIGHT FA codes.
There are two types of 2021 R1250GS LED HEADLIGHT.
One is 63128395632 adaptive led headlight.
One is 63128395631 led headlight.
If 2019 R1250GS is modified with 63128395632 adaptive led headlight, the FA code needs to be modified to 134 (Adaptive Headlight) and 219 (Headlight Pro).
If 2019 R1250GS is modified with 63128395631led headlight. Does anyone know what number’s FA code needs to be modified?
Thanks.
Re: 63128395631 LED HEADLIGHT FA codes
Beitrag von Werner »
Found this one : ?
kuanyi
Taiwan
The FA code of 2019 R1250GS led headlight is 192.
2019 R1250GS is modified with 63128395631 led headlight(2021 R1250GS LED HEADLIGHT). Have ridden more than 2000km. Both the low light and the high light are normal. The instrument has no fault light.
But GS-911 there are Fault Codes 6 in Body Controller Lite (XBCL)
LED Coding resistance defective
LED internal error
LED Temperature sensor NTC1 faulty
LED Temperature sensor NTC2 faulty
LED Temperature sensor NTC3 faulty
LED message timeout (Status_LED_Scheinwerfer_Motorrad_2010_LIN)
I think the code is incorrect.
Hat sich bedankt: 12 Mal
Beitrag von rinalds2m »
What option code have You coded right now? Have You removed 134 and 219 and coded 192 only?
If you get errors it means that you have coded something that is not connected/present in your bike.
See the pics with available options for 2019 and 2022
kuanyi
Taiwan
My motorrad is a 2019 R1250GS HP. The code is still FA 192 for the 2019 R1250GS led headlight.
The original motorrad code is only 192 on SALAPA. I didn't add or delete 134 and 219.
I know 2019 R1250GS is modified with 63128395632 adaptive led headlight, the FA code needs to be modified to 134 (Adaptive Headlight) and 219 (Headlight Pro).
My 2019 R1250GS has been modified with 63128395631 led headlights (without Adaptive Headlight).
Thanks.
Maybe try to initialize the headlight with ISTA.
If that does not help, try to update software for all ecu's in your GS.
If inside the headlight is some ecu, then the software must mach with bike's software.
I am not a professional in this - these are just my suggestions and thoughts that I would try in your case. ;)
